Replacing hot water and heating system - but what with ?
1 Dec 2011
Surrey
Currently I have a gas boiler feeding the central heating on radiators (8) and towel rails (2) plus 2 bathrooms with showers and 1 kitchen sink.
It is an old fashioned tank fed system with a store of hot water (limited and not enough) and an immersion backup.
I have elsewhere and want unlimited hot water. My understanding is that if I go down the combi route, operating two showers at the same time might be a problem whereas with in situ electric showers, that problem is overcome.
What is the best modern option ?
31 May 2016
You start by measuring your mains cold water flow rate. This will determine what you can do. 12-15 litres per minute is where you want to be.
1 Dec 2011
Surrey
Thanks.
I assume this is with a prospect of moving everything from tank to mains fed ?
11 Jan 2010
London
Electricity is 4 times the cost of gas. Also running 2 electric showers at the same time may not work depending on your mains flow rate.
1 Dec 2011
Surrey
A requirement will be to be able to run 2 showers and a kitchen tap and have no disruption to the hot water availability or the temperature.
I have run those before from a 300/400L Megaflow on economy 7 electric with mains feed but there was no gas at that property. Now we have gas in this one, I would like to take advantage of the cheaper costs but only if the system can deliver the requirements.
11 Jan 2013
Durham
All sorts of options. As above, get dynamic pressure and flow measured, no point chucking a Megaflow at 1 bar 12 l/min.
A sensible size combi will run 1 shower ok but not 2. You can run a cylinder etc on a combi boiler (it's another heatsink) so, for instance, you could run kitchen and one bathroom from the combi and the 2nd bathroom from the cylinder. If mains flow/pressure isn't brilliant then keep the gravity tanks, add a shower pump if you need to.
