- Joined
- 21 Sep 2015
- Messages
- 62
- Reaction score
- 0
- Country
We're having a few problems with low hot water pressure and shortly I'll be renovating both bathrooms and hopefully swapping the electric showers for mixer showers. Here's a breakdown of the current installation:
Q1 I'm guessing the best solution would be to get a 3 Bar pump for the hot water to roughly match mains cold water pressure for kitchen mixer taps etc?
Q2 When I replace the electric showers for mixer showers I'm guessing I'll need to have a second cold water feed from the CWS tank in the loft and via the 3 Bar Pump (dual type)?
Q3 Will it be feasible to still run all of the taps in the house from the cold water mains whilst running the showers on a separate feed, and how much ripping out of pipework will be involved?
Q4 Will I need to increase the CWS tank / cylinder sizes?
Q5 Decent whole house pump and thermostatic mixer shower recommendations?
Q6 Do I need to consider pressure rating of anything before installing pumps, and is there anything I've overlooked?
Q7 Rough cost for the above, doing it myself vs getting someone in?
In terms of ability, I'm an instrument/electrical tech with pipe fitting background so it is something I'm fairly confident doing, once I have done all of the research etc.
Thanks in advance, and sorry for all of the questions. Even if you can answer one or two of them it would help me get started.
- 4 Bedroom House - 2 Showers, 1 Bath, 6 sinks total.
- Open Vented Hot Water/Central Heating System with 114 Litre CWS tank in loft / 131 litre cylinder in airing cupboard.
- Upstairs Hot Water Pressure: 0.2 Bar (approx 2 metres head)
- Downstairs Hot Water Pressure: 0.4 Bar (approx 4 metres head)
- Mains Cold Water Pressure 3.5 Bar.
- Barrier pipe installation (Hep2O) 10mm/15mm/22mm.
- All cold water systems currently mains fed.
- Currently only 2 adults/1child sharing but I'd like to future proof for full occupancy!
