My immersion heater element broke sometime ago and I never bothered to replace cause the boiler is a lot quicker. I currently use the immersion heater socket for my power shower with a low amp fuse in.
Depends where your pump is on your system as to whether you need to drain the entire system or not (IE if it's upstairs you only need drain upstairs). Remember to add inhibitor when you refill.
