I have a combi boiler that gives us piping hot water when set to hot water only. However, now we have started to use the Central Heating we have noticed the hot water only gets slightly warm. The boiler is set to 'Hot Water and Heating' and the CH is left on for long periods. I should say the central heating it working well and pumping out the heat. But it seems the only way to get hot water again is to switch the boiler back to 'hot water' only and then when your done switch it back to 'hot water and heating'...not great!
I should say the boiler was serviced recently and had a new heat exchanger put in.
Any ideas as to what is causing it?
Thanks mark
Thanks mark
