Been reading a lot of posts and I think I've narrowed down my problem, my Baxi 105e has a "hot water sensor" fault lit up, and I narrowed it down to a Diaphragm that has been mentioned, however where do I get one? is it easy to fit, any help appreciated.
if ya boiler is showing a fault code suggesting there is a fault with ya hot water sensor it is unlikely to be ya diaphragm (if the dhw diaphragm had split it just wouldn't show a demand).. have ya changed the thermistor?
When looking at previous posts and cross referencing with my problem the common denominator appeared to be a diaphragm, if it isn't fair enough, but looking through the site my specific problem pointed to that,i.e my hot watew sensor lighting up as a fault and lack of hot water from the tap/heating.
