I have an older central heating system using two pumps, one for CH and one for hot water.As a new radiator was fitted I put an inhibitor in via the header tank.Since then the hot water has not heated. The pumps are working OK but the return pipe for hot water is barely warm. I suspect the pipes have become blocked.The radiators are working fine except for noise that sounds like marbles rattling in them when very hot,and a fair amount of bleeding occasionally. Should I attempt to flush the system from the mains. If so, how please without causing water to pour through the ceiling ? Thanks
