D
Deleted member 267285
That should show me if the MV for the HW is working correctly or not Y/N ?
No. If it’s working correctly, then I doubt we’d be here discussing it. The only way to test it properly, would be electrically, using a multimeter. If when you select the heating to fire the boiler up tomorrow, manually latch open the valve and water heats the cylinder this would tell me something inside the actuator has failed (motor or microswitch). If you’re capable of replacing one, without the need for draining down then you can fix this yourself.
