Hotoint WF541
29 Sep 2009
Cambridgeshire
Hi! I have a problem with washing mashine. It starts normal, but after few minutes the light 'Rinse hold' and start button light starts flashing and the washing stops. What should I do and what kind of problem it should be. Water is getting in and out normally and pumps are checked and cleaned, filter too.
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty . new pcb needed try here http://www.emwelec.co.uk/
yes but they work in reverse . door lock light is number one, spin is number 2 .these are on the right hand side not the left.
