    Dismiss Notice
Hotpoint 1st Edition 1000 wont turn on..
Discussion in 'Appliances' started by BlueDuckEgg, 23 Jan 2011.
  1. BlueDuckEgg
    BlueDuckEgg
    23 Jan 2011
    2
    Thanks Received:
    Tyne and Wear
    Country:
    Hi folks,
    Really hoping someone here can help, got the old washing machine in the title with a small problem... The door got stuck shut for some reason but managed to get it unlocked - had to take the lid off and press the little latch on the back of the door lock to do so - put it back together but now the thing wont start at all...
    I've checked all the connections in case I caught something (also looked for some kind of lid-switch in case there was something to stop it running with the lid off) the fuse in the plug etc. Had a look through the net and came across suggestions regarding the vacuum pipe thing getting blocked so checked that at well - can blow air through it towards the drum and can blow air to the solenoid thing and hear it clicking under positive pressure but I'm not sure if that proves anything?
    Any ideas? Really can't afford to get a new washer at the moment!
    Thanks in anticipation!
  2. Sponsored Links
  3. rocks1
    rocks1
    30 Apr 2008
    6,138
    Thanks Received:
    1,041
    Country:
    Check the timer for burnt track. It wil be on top at the from where the first black connector is. If it's lifted the Track then resolder and replace door lock. What date code have you got on the door lock has it ever been replaced.
  4. BlueDuckEgg
    BlueDuckEgg
    23 Jan 2011
    2
    Thanks Received:
    Tyne and Wear
    Country:
    Thanks for that, I'll have a check later. As for date code, no idea, I'll check that as well but I doubt it's ever been replaced, washer belonged to my friend who bought it, used it for a couple of years until she moved in with her boyfriend and it sat in storage until I took it off her hands a couple of years ago after my last one died a death!
    Cheers
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
