Hotpoint AQLF9D69U autodose problem ...
DNL
17 Feb 2012
Dear all,
I bought a couple of days ago the Hotpoint Aqualtis Auto dose washing machine. Now to the problems ... According to the manual, I loaded the machine with detergent and Softener. Checked both tanks and they are completely full. The LCD though, does not show the level in the corresponding items, it thinks that both tanks are empty. When I press either button to increase the dosage the screen shows ''LF 400'' , beeps and then goes back to normal. There is an option to manually set the machine to clear the tanks in case of an error (for example may be by mistake you have put the softener in the detergent tank etc). I run both the detergent and the softener tank cleaning cycles and the machine did not empty anything at all. ... I think the problem should be in the level switches but know nothing about washing machines. Underneath I found a couple of peristaltic pumps but I dont know if these are the ones that do the dosing in the drum ...
Any help appreciated ..
Dimitri
