Hi there,
I have a Hotpoint Aqualitis AQC94F7E1M Tumble dryer (just over one year old, obviously!) which is leaking water underneath the machine. The clothes are coming out dry but no water is collecting in the water tank so I suspect something is going wrong between the drum and the tank but not sure where to look.
The filters are cleaned after each cycle, it lives in the kitchen which is warm enough, there is a good few inches of airflow around the machine. I was experiencing the problem while it was in the garage but moved in in as it was too cold out there. first two cycles worked ok and the tank needed emptying but in the last week it has reverted to coming out of the back again.
Any help would be appreciated and if possible guidance as clear as - I'm not great with appliances so 'clear the pump' on it's own may not be that helpful for me
Thanks in advance
Thanks in advance
