Continue to use it without salt for a couple of days, if that solves the problem its most likely the valve.
It is also worth checking that the salt cap seal is ok and no splits in the top, some caps have a plastic window that splits with age.
Then by disconnecting the wiring to the valve you could see if the problem persists with salt in the container. If it persists then the valve is stuck open. If not then there is probably a fault on the control board.
