Fo6 surposed to mean door lock. Are the lights flashing or on constant. Make sure connections are tight in pcb. Also unplug it for 5 mins and then try.
I tried it on the spin cycle only and waited as it finished. The light came on to say finished with the red light showing the door was still locked. Next thing I kine all the lights were flashing and it seemed to start up again. I switched it off at the mains immediately and opened the door with the emergency release tab at the bottom. The washing was spun so it had completed the cycle.
