Hi Guys, googled my problem with washer and found this forum so would be very grateful of any helpful advise you can give.
I have a hotpoint Aquarius WF 320 (1200 spin) washer, which has the following problem.
Stopped mid wash, so switched it off at mains to try to re-set it. Which it did but as soon as you try to set a new program the lights jump straight to 'door locked - flashing' and 'Wash - on permanently'.
From the list of error codes below am I right in saying the pressure switch isnt sensing? can you advise what my next move is?
(Error list supplied on link http://www.diynot.com/forums/viewtopic.php?p=2810930#2810930 )
Much appreciated
Brian
Posted: Thu May 13, 2010 1:22 pm
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Much appreciated
Brian
f16 N/A
