Hi, Just put on the washing machine and its currently not working with a lot of lights flashing!!
So I've done a search and it would appear that the left hand light (five of them) the first 4 from the top flash and also the final spin light + on off. Now using this and rocks list see below:
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Would this mean Dryer heater relay? But just a bit confused as its a washer not a washer dryer.... We also had pipes burst so could this fault becaused by a frozen blockage?
f16 N/A
