hotpoint aquarius wf250 flashing lights ???error messages???
25 Mar 2007
This is fault F07 - heater relay stuck. The most common problem for this is the pressure switch sticking. This is the fix - unplug appliance from mains, remove top, disconnect pressure switch hose from switch, tap switch on tor weight a few times, refit hose, reassemble and test. If this does not work check wiring to heater and meter.
i have tapped the pressure switch and that seems to be working fine , we blew up the pipe and it clicked and unclicked.
the machine filled up and it proceeded to wash but upon touching the glass at the front of the machine , the water was still cold
when we took the pipe of the bottom to check the filter we found quite a few coins and fluff could this have caused damage to the heating element ?
The components which cause this error can be any of the following, heater, ntc, module and pressure switch.
