This is fault F07 - heater relay stuck. The most common problem for this is the pressure switch sticking. This is the fix - unplug appliance from mains, remove top, disconnect pressure switch hose from switch, tap switch on tor weight a few times, refit hose, reassemble and test. If this does not work check wiring to heater and meter.
