I have 2, both with different 'timer' boards which have the heater relay on and the only difference I can see is a 2watt 100 ohm resistor as opposed to a 130 ohm.
Incidentally, the 100ohm board is from a machine that apparently needs no further action and theres no sign of stickers that they usually put on them after recall repair work.
