Hotpoint Ultima WD71 front panel buttons
27 Nov 2006
Surrey
hi
my hotpoint ultima wd71 front panel buttons are NOT doing what they say
for example if i press the drying button the info display shows that i have pressed timesave button etc etc
which part is most likely faulty
take the ribbon cable out behind the panel .clean it ,poss sticky buttons but that part is now obselete. :(
ok rocks1
i understand the clean the ribbon
but when you say sticky buttons but the part is now obsolete
all the buttons make a 'beep' so that means something is working surely
the ribbon cable behind the consol panel is obsolete .it may need just cleaning are the buttons sticky .take it apart and look.the ribbon cable can short out if its had something spilt on it.
problem now solved
checked the ribbon seemed there was a kink in it but that was working fine
cleaned behing the buttons - a little bit of dirt there but nothing too major
the fault was the circuit board
but i can't see any burning or brakages anywhere in the lines
Thanks. I'll see if I can get a replacement board at a sensible price. Lowest I have seen so far is £64. As the machine is over 10 years old it's not worth spending too much on it.
What about qer.biz
That's great. To repair my cards(s) is £48 (Non trade). Now I need to decide whether that is better/easier than just buying a replacement card for another £16!
Many tx.
What about qer.biz
Many tx.
Give Create Recycling in Liverpool a call. They have stocks of WM parts that I think they will sell. They may ask for your old one back if its repairable?
