Recently done some repairs on my Hotpoint WMA35P.
The machine stopped working after a few very noisy washes. On inspection, the drum bearings had rusted and shattered. I have replaced them and also put in a new heater element.
The repairs seem OK, but the machine will still not run properly. I did a component test which has indicated a problem with the motor.
During manual component test of motor (which should initiate slow tumble) there is a regular repeating click from somewhere on the PCB but no action from the motor.
I've had a look at the motor - the brushes and armature both seem OK. I am wondering if the tacho is the problem. Is it possible this could have been damaged as a result of the corroded bearings? The belt was off at the point of total breakdown.
Interested to hear any suggestions for (a) checking whether the tacho is faulty (b) possible alternative problems (c) whether the tacho can be repaired or where to get a replacement.
Thanks for reading.
Thanks for reading.
