Hotpoint wf541 washing machine
10 Feb 2012
West Glamorgan
Hi
The machine is not heating have power at the heater, the element is giving 30 ohms and the thermostat 30kohms. No lights are flashing to give error codes. They were a while ago but switched the power on an off and this cleared it. The machine has worked since then. Goes through the cycle ok but with cold water.
Any help gratefully received
How do you know it's not heating it should error out if it dont heat. Put it on 60 and wait for 10 mins then remove dispenser draw and you should here a hissing noise of the element.
Hi
I was checking for voltage supply to the heater element while in the cycle. However, have taken out pressure valve, pcb and pressure switch replaced and is now working???
