hi folks, great forum
my machine is flashing up with two faults depending what cycle I try
F01
or no water supply(this would appear to be the actual fault)
basically it isn't filling with water, however I removed the pipe from the pressure switch and blew it through until it was gurgling nicely, connected back up and switched on, and great the water stated filling again for a few minutes then it stopped and the fault No water supply came back on, there is now a lot of back pressure and I can't seem to get the pipe clear
any ideas?
I did a search on here and found another post with the exact same fault, but the final solution was unclear as they called an engineer out in the end
F01
any ideas?
