As title says, I have a broken Hotpoint WML540G Serial No# 54701 903251378
The wash unit has packed up and is sealed so can't replace bearings. I'm loathed
I will have to buy another machine but I have all spares available in perfect working order. I will be stripping the appliance so the metal rear case, wash unit and door seal will be binned as they are of no use. At time of posting all other spares will be available inc PCB's, Motor, drain pump, solenoid valves, pulley wheel, detergent, door lock, door unit, wiring harnesses, front control panel, etc etc. If anything is needed then please give me a shout and if you need it and I have it I'll let you know.
Jon
Jon
