hotwater tank
27 Feb 2010
Worcestershire
I've to change a motorise valve on my CH, and make it easier I was going to remove the short piece of 22mm pipe attached to the hot water tank.
The tank is about 10 years old and I'm worried about trying to undue the connection to the tank, do the compression nut come off easy, as I don't want to damage the copper tank?
Where possible, avoid touching the tank connections. Sometimes they undo easily, other times they don't and if too much effort is putting into turning them, they can distort the tank causing a leak around the joint.
By loosening the pipe from the pump and the hot water flow (ie, the other 2 connections) you should all being well have enough play on the pipes to get the valve body off easily enough.
the problem I have is there is no room to move the pipe to the right hand side of the valve as its against the wall.
