Hot Water Cylinder 28mm compression fittings 22mm pipework
Discussion in 'Plumbing and Central Heating' started by testsubject12, 28 Nov 2013.
  1. testsubject12
    testsubject12
    21 Oct 2010
    17
    Thanks Received:
    Suffolk
    Country:
    I've had a leaking hot water tank for about 6 yrs, it's just a very very slow weep but it's about time I fix it. :!:
    So a friend of mine had his heating system switched over to a combi so has a <2 yr old tank going spare.
    It's exactly the same size and pipe positions as mine, so I thought great an easy job :D
    Unfortunately after draining the hot water tank and disconnecting the leaking tank I discovered that the compression fittings are 28mm and not 22mm like the old tank.
    My question is, is there such a thing as a male 28-22mm compression fitting reducer, I can find reducers that do 28-22mm but they are always female to female (If I'm assigning the gender the right way) ;)
    If there isn't whats t he best course of action.......
    Cheers
    Paul
  2. Sponsored Links
  3. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Better way - get 22mm x 1" connectors, available in male and female.
    • Thanks Thanks x 1
  4. testsubject12
    testsubject12
    21 Oct 2010
    17
    Thanks Received:
    Suffolk
    Country:
    Yes, that does make sense, modify the tank to fit the pipework rather than adding something in between :)
    Like this: http://www.screwfix.com/p/conex-male-coupler-302-22mm-x-1/64912
    Guess I should check the diameter of the thread pattern inside the tank once I've removed the 28mm coupler already fitted to the tank.
    Thanks for the reply.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
