Gender questions - for a hot water cylinder
2 Mar 2015
Devon
Looking for some advice on fittings for vented hot water cylinders……
For the coil, 1” male seems standard – would changing this for either a 22mm or 28mm compression fitting be £20 well-spent?!
Similarly, I can change the gender of the cold-feed and the hot-water draw-off from female to male for £10 each – should I? Or, should I get a compression fitting here too?
Advice much appreciated…..
Crawf
22mm compression (or 28mm if required) does make everything easier. That's how every connection arrives when ordered from Gledhill for the company that I work for.
I don't exactly understand what you are trying to find out.
Probably most normal domestic cylinders are now fitted with 22 mm compression fittings.
But I wonder if you are really thinking of pipework sizes.
Tony
As above, Gledhill come with compression fittings as standard. Whether you need 22mm or 28mm depends on your heat source
