Hi - I am in a similar situation. 8 year old townhouse built by a well known house builder but not without its problems with corner cutting that I am discovering as second owner. Our house is freezing despite large radiators that should be sufficient and having them balanced. There is a lot of heat output but it is being lost somewhere.
Could someone suggest a way to check the downstairs outside facing wall's insulation? Could I cut a small hole in the wall from the inside and check somehow? If so, what would I be looking for?
I am considering adding insulating wallpaper to the outside facing walls (Erfurt Thermal Liner brand used at my parents works well) but it is rather expensive
Many thanks for your advice in advance
Laurent
Laurent
