Hi Chaps,
We're decorating the house from top to bottom, although renovating is probably a more appropriate word. Pipes 'ping and ting' when the heating is on, and the flooring could do with some love - so I'm planning on pulling up all of the tongue and groove chipboard. I want to make sure that pipes are lagged at joists, and generally inspect.
I was thinking about relaying plain 18mm ply for the floor, with joins on the joists. I hate T&G, I hate chipboard, and ply seems to be recommended.
The radiator pipes all come up out of the floor in the middle of the radiator, then branch off to the sides. I assume this was done to save time notching an extra 4 or five joists, but it looks sodding awful; I plan to solder some extra pipe and notch the joists. Nobody can think of any other reason for this to be done, can they?
The radiator is on an exterior wall, and I'm sure I recall reading that you aren't supposed to notch within a certain distance from the end of a joist - is it better to use a hole saw and feed through the middle?
Lastly, and ultimately least importantly, I was planning on using chicken-wire and rockwool to insulate between the floors. The bedrooms can get a little warm, so it seems like a cheap and way to help with the heat bleeding through from the living room. A TR on the new radiator might do the job, but I don't want to bring the floor up again later.
Could anyone offer suggestions as to anything else I might want to do, while the room is being ripped apart? Any criticisms of my (relatively basic) plans would also be appreciated.
