Hoval Topgas 45-4
26 Sep 2009
London
I am looking for an installation manual for one of these... can anyone please help?
Many thanks, will be fitting it in the new year.
Weird I always find an installation Manual in the packaging with the boiler- or has it fallen from the back of a lorry?? :confused:
yeah its 2nd hand... going to rip out the potterton, although I also bought a Keston C55 of fleabeay too, just in case there is a problem with the Hoval... the hoval is about 3 times larger than the Keston...
Whatever happened to Whole house sizing?? Good luck with that ;)
I have a 50KW Potterton in situ, and the Hoval is 45Kw, the Keston 55... but the Hoval is about 3 times the physical size of the Keston... the Keston is pretty small actually, the hoval is about the size of a medium fridge, but I am excited about fitting this.
The issues I have are that will Hoval want to know when I call them, and explain that the boiler is used?
I have had a look at the boiler and the installation, and there's more to it than normal...
I am not fitting this myself by the way, I am just doing some preliminary checks...
I have 4 wires comming out of the Hoval, I take it power, pump, frost stat and thermostat... I will also have to reduce the water pipes from about 35mm to 22mm.
I was also hoping to get it checked over by someone from Hoval, to optimise it, and I may get a service contract if it's reasonable enough...
what are your thoughts on that?
Hoval will want about £300 + Vat to commission it (they charge a day rate for everything) you will have to make sure it is installed to the letter, or the Engineer will walk away leaving you with the bill ;)
Hoval probably wont commision it cos its second hand.
If they do it'll probably be one of their buisness partners/commisioning firms such as Instatherm that will come and do it.
Shame you've bought a Keston,a new one is bad enough but 2nd hand your really running the risk.
the C40/55 suffer with the following, PCB failures,fan failures,electrode droop, internal flue hose failure and split HEX's but dont let that put you off.
Kestons only last and work reliably on a clean well designed system normally feed into a low loss regardless.
Have you worked out how your connecting your 2 boilers.
No I want to fit the Hoval, but if I get any issues, I will fit the Keston.
Is there anything I should be aware of when fitting theis Hoval... like it not working without some code from Hoval or anything??? I donlt want any nasty surprises
pmsl :LOL: :LOL: :LOL:
Thought you'd like that. :LOL:
Nasty surprises-no easy to fit if a little large, easy wiring...depends if all the bits are there and your installers fitted Hoval before.
