How am i still alive ???
30 Mar 2011
Manchester
Right well today, in a storage cupboard between two flats, on a pair of metal step ladders one arm resting on a cast iron soil pipe, looking through a hole with a small penlight plastic torch.. WHEN the torch touched a bare live wire which my boss had left exposed ( i know, what a d**k, i had a kind word with him) but yeah i got a right belt, i felt it through one arm across my chest and too my other arm on the cast soil pipe, the RCD did not trip.. so ifit only takes 6 miliamps or what ever across the chest to kill you, how am i still alive :S??
Good fortune?
Assuming that the RCD was working properly, then the shock current must have been below its tripping threshold. A few milliamps can still give a very painful shock, but not necessarily fatal. It depends upon the current level, duration of contact, your physiology, and so on. A shock of a particular magnitude and duration, across the same body parts, can prove fatal to one person but not another.
It's not like some horror picture where the mad doctor is trying to extract information from some helpless victim he has wired up and is turning up the juice with a "When the dial reaches 500, you will die" line. It just doesn't work like that - There are too many variables.
Boss?
Sounds like a complete numbskull to me.
Where was his safe isolation??
I can't believe he has the nerve to call himself your Boss when he acts like that.
A similar thing happened to me, although it was not an electrical injury. I needed loads of time off to heal the injury (a dislocated shoulder) and ended up being "let go". Whether or not that was prompted by my suing him, I'm not sure...
Let me tell you what would happen in our firm.
We would have to report this ASAP as an accident to the relevent people.
We would then have to down tools immediately and ring our manager, who would have taken us to hospital to be checked out as a victim of electric shock.
If the accident was RIDDOR reportable, that would be reported as such.
We would then be suspended on full pay pending an internal investigation. If that investigation proved that we had worked contrary to our procedures, then disciplinary action would be taken.
The kind of incident you describe would, in our firm, very likely lead to the dismissal of all those involved on that job.
The reason being that HSW places the onus on everyone to work safely and to speak up if safe procedures are being ignored.
I would suggest you report it as an accident and get checked out medically just to make sure you're OK and cover your a$$.
He says it was my fault as he said " i'd seen him cut the wires' a good few hours ago ! so i suppose i should assume that hes left them bare and live rather than safely isolated ! this guys only a joiner and is always doing dodgy things like this, he doesnt care to health and safety, all hes botherd about is his pocket ! its only me and him at work so no actions would be taken and he`d just tell me to be careful.. but i cant find any other jobs :|..
Sorry - I know times are hard etc, but the guy is a dangerous and callous scumbag.
He needs to be locked up.
And if you are the spark and he's the joiner why is he cutting through cables? :shock:
Who said he was either?
Don't forget that RCDs also need regular testing if they're to retain their 30mA value.
It seems strange that a plastic torch should conduct enough electricity to give you a shock. I suppose if it's got some sort of foil skin it may be enough to conduct some current, and thankfully limit it.
Paint, rust, poor eaths etc can also help limit the severity of a shock.
A short sharp even a severe shock is unlikely to prove fatal from heart failure.
It may stun a healthy heart and make it miss a few beats before it re-starts beating normally. This is the method by which an in-effective heart is re-started beating normally by a de-fibrilator where a massive shock is passed directly across the heart.
A continuous shock can cause non reversable bio chemical damage from which the heart and other organs cannot recover.
The reflex actions of limbs involved in the shock will act to disconnect the body from the source of current long before any serious damage can be done.
But DO NOT test this as an un-healthy heart when stunned may not be able to recover a normal beat pattern. That is the situation when a de-fib fails to re-start a heart
A short sharp even a severe shock is unlikely to prove fatal from heart failure. It may stun a healthy heart and make it miss a few beats before it re-starts beating normally. This is the method by which an in-effective heart is re-started beating normally by a de-fibrilator where a massive shock is passed directly across the heart.
That's only true of DC (as in defibrillators) - so what you are saying is misleading. The risk with exposure to one cycle or more of AC (20ms) is that of inducing ventricular fibrillation (and 50Hz is close to the 'optimum' frequency for doing that) - if that happens, nothing other than a large DC shock (from a defibrillator) will 'stun' the heart into a quiescent state, hence (hopefully, not guaranteed) allowing it to re-start beating normally - hence 'bringing you back from the dead'. Ventricular fibrillation very very rarely goes away on itself, so is nearly always fatal, unless treated (terminated) immediately.
Kind Regards, John.
John
Early de-fibrillators gave a DC shock by discharging a capacitor onto the pads but modern de-fibrilators with the advantage of modern reliable electronics give a bi-phase shock of controlled current.
This is quoted from http://incenter.medical.philips.com..._Sheet_(TDS)_(ENG).pdf?nodeid=577848&vernum=4
Philips Healthcare’s M4735A HeartStart XL offers advanced
and basic life-support clinicians a compact, lightweight, easy-touse
defibrillator/monitor with both Manual and AED
capabilities. HeartStart XL features Philips’ patented SMART
Biphasic waveform, ECG monitoring, synchronized
cardioversion, and optional non-invasive pacing and SpO2.
A biphasic waveform is energy delivered in two phases. During
the first phase, the electrical current passes through the heart
muscle, reverses direction, and then passes through the heart a
second time. This efficient transmission of energy requires less
current than that delivered by a monophasic waveform.
It's not just 'modern' - for about 30 years, 'biphasic' defibrillators have been pretty standard, development having been fuelled by the need to minimise current/voltage requirements so as to facilitate the production of implantable defibrillators.
However, it's still essentially DC. The 'biphasic' approach involves what has come to be known as the 'Lown waveform' - an initial large pulse of one polarity, lasting about 10ms, followed by a very much smaller (typically about 5%) pulse of the opposite polarity - created by discharging a capacitor through an inductor. It is sometimes described as 'a highly damped sinusoidal waveform', and is damped so heavily that it is effectively limited to one 'cycle' (1.5 at most, with the final half-cycle being tiny in magnitude). A typical waveform is:
As the material you quoted says, the second, small and 'negative' pulse appreciably reduces the amount of current (hence voltage) required for effective defibrillation. The crucial thing is that it does not have a 'second half cycle' anything as large as the first, and essentially only lasts for 'one cycle' - conditions necessary to prevent it being more likley to cause than to terminate ventricular fibrillation. If AC would work, we would obvioulsy use it (maybe even limiting duration to one cycle), since it would be electronically much simpler, and would not require the large capacitor which results in much of the bulk of defibrillators. The earliest defibrillators (in the 1950s) did use AC, and were relatively rarely effective.
Kind Regards, John.
Again quoting from Philips public domain documents.
The Lown waveform is that which one would get from the discharge of a capacitor via an inductor into a complex impedance such as that which the human body is. The second half cycle is the energy shock stored in the body returning to the capacitor and was not "intentional" from the de-fib.
complex impedance = resistance, capacity, inductance and chemical storage ( as in a fast acting battery ) and other factors. In the 1960's testing of de-fibs involved a dead pig's body as the best ( easiest with available technology ) simulation of the human body.
The second half cycle of the modern bi-phase is intentional and the current in the second half cycle is sourced and controlled by the di-fibs electronics. If I recall correctly the second half cycle is intended to rapidly restore the electro-chemical status in the body that the first half cycle would have disrupted. This restore would occur much slower by passive dis-charge of energy from the first half cycle stored in the flesh.
Survivor Bias in reporting.
The only reports you see from people who have been in life-threatening situations are from the ones that weren't killed.
The ones who were never say anything.
BTW I presume you know that people who have been shocked are advised to go to A&E since some of them suffer a heart attach hours later.
Are you still there?
