I needed to change rusty cold tank anyway so have got a 150L Ariston Aquabravo 150L cylinder doing away with cold tank.
I ditched storage heaters and we have fitted a wet CH system. It is a well insulated late 80s 1st floor flat. An energy saving expert felt the wet CH wasn't too bad an option for me giving good controllability and due to the good insulation etc hopefully wouldn't need run excessively.
My problem is really this. I didn't expect this modern immersion heater to ideally need 3 hours to heat fully. I expect in reality it'll provide HW more quickly however running it on E7 overnight it will be on for an uncontrollable long time.
We feel Our E10 option isn't actually all that cheap and the time periods are a bit restrictive. Our plan was going on to a good single tariff which we have in mind at 11p/u.
This flat is for renting out. I am now completely confused about how best to run the cylinder. If it only needed to be on for an hour and half then I'd say fine, just time it to come on early morning and it'd provide enough water for a couple of showers.
I can use my E7 but if the cylinder kicks in at midnight it'll only go off at 3am when fully heated (being on so long will be fairly costly). This would be ok if the peak rate wasn't so high for boosting and running the electric heating.
In reality how long do you think this modern cylinder will take to heat up enough for a couple of showers or a bath? I have also been considering sticking with an electric shower so as all this water heating can be avoided.
Probably my worst fear and surprise is the supposed time this modern cylinder could take to heat up. The unbiased energy saving consultant felt controllability was the key but E7 combined with high peak cost isn't ideal. I have had E10 prices and they're not looking great compared to a good completely flexible flat rate.
Please help! I'm booked for a new single supply meter this coming week as well as needing decisions on connecting up the system, most of which is fitted
Thanks!
Thanks!
