How Can I Fix a Broken Door Frame from door being kicked in?
4 Apr 2013
Yorkshire
The door itself and the hinges are fine
but the door frame has split where the hinges were pushed out
How can I fix the frame?
Are you talking about making the frame temporarily secure, or a more permanent measure?
If its the former, close the door and fix timber battens across the frame from the inside. If its the latter then the split can be glued and cramped and any holes filled with dowel - and then its probably best to shift the hinge position a little. It really depends on how bad the damage is!
John :)
John :)
Top piece is better than the bottom
on the bottom a piece has come off...
I want something quick and cheap really!
Post us a picture of the damage....most burst frames can be repaired if the joiner knows what he's doing - it depends on whats left of the frame.
John :)
So if I move the position of the hinges...
Bring the top one down a bit and raise the bottom one up a bit...
And then with a combination of wood glue and wood filler, patch the frame back together
then sand and gloss the whole frame so it blends in?
Would that work?
This is the bottom, and the piece that came off
And this is the top, the hinge is still attached here but loose
You'll probably get away with what you propose, but that split piece has to go back into place.
Wood glue only really sets perfectly when its cramped up, or otherwise squeezed (with the addition of screws, maybe.) The adhesive must be allowed to thoroughly set, too. Don't rely on filler for strength, only aesthetics.
A skilled joiner could splice new timber in there, but there's a couple of hours work!
John :)
