How can I tighten sink waste behind pedestal?
11 Oct 2016
Hi, I can't remove my sink pedestal as it's too tight against the sink.
I need to at least tighten the inline trap.
Or at worst replace it.
I was thinking of trying a strap wrench to try and get in there.
If not I'm thinking smash the pedestal to gain access and then try to get a similar sized pedestal.
Does that sound like the best way of doing it?
1. The most common arrangement is for the basin to be bolted to the wall as well as resting on the pedestal.
2. If yours is done this way, it may be difficult to loosen the pedestal because there is no movement in the basin owing to the bolts.
3. If this is the case consider loosening the bolts (or nuts on studs) and see if that gives enough wriggle room to shift the pedestal forward. Don't take it right out, it must still support the basin.
4. Also be aware that:
4.1 The basin may be siliconed to the wall, as well as, or instead of, fixed with bolts. You would need to cut through the silicone.
4.2 The basin may also be fastened to the pedestal with silicone. Again you would need to cut through it.
5. If you go for the smashing the pedestal approach, I'd try and find a replacement pedestal first.
If it’s just the trap then these are usually hand tight. If it’s the slotted waste then sometimes suitably sized pump pliers or footprint wrench can do it.
Peds usually have bottle traps which require no more than hand tight - why not post a pic.
It may just as well be easier to take the whole thing apart then put it back together.
