I need to replace my current (broken) cooker.
The cooker currently in use is a Zanussi ZHF865X and is rated at 5.5kw which i calculate as ~23amps (5500/240). The currnt circuit breaker attached to this ring is a B30 (which i assume is a 30amp breaker). This seems massive overkill and surely is wrong? By the time it breaks wont the cable have melted??
Looking at the cable from the wall to the cooker i think it is 6mm (to be honest it is very hard to tell with my limited experience). How can i tell?
--- So onto my question --- (finally)
I am contemplating replacing my oven with a Indesit FIU20IX and all i can find about this cooker is that it is a class C - ( i think it is 7000kw) , which means 30amps.
Does a class C oven mean it is rated at certain kw??
I guess i really need to understand the size of cable that is already installed (not the cable to the cooker) - looking in the CU box I could not make head-nor-tail of it ? - and i dont want to mess/touch that ?
How is cabling actually measured - i thought it would be a cross section but it makes no sense I cannot tell if the current cabling is 6mm or 4mm etc?
Sorry for this long drawn out post
And thanks
And thanks
