Ok, so now I am really confused. The Engineer has stated that he has issued a warning notice and used his discretion to allow the temporary use of the appliance. His test figures show passes for flue operation checks. What is my position now - could he come back and disable the appliances?
Apparently there is no insulation around the feed pipe taking the gas pipe through the brickwork - needs rectifying
If he ar the job then he should have asked your permission to switch off the offending appliance. I take it he did not ask you? If he did you are within your rights to refuse.
I always advise landlords to directly employ an engineer (RGI) for Certs.
My charge is typically £65 for a single Cert but many agents add on about £20 or more for their commission EVEN if they have a full management arrangement.
RGIs working directly for agents are often more strict over borderline cases. Perhaps because some agents give them remedial work without any interest in the prices.
