How do I connect these wires to the wall light?
3 Nov 2006
Belfast
I have bought a wall light to connect up to the wall in a newly built extension. The electrician left two grey cables sticking out of the wall for this purpose.
The two grey cables are I assume on a loop, the wires inside the grey cable are live and are covered up with a blue electrical tape. So I will obviously turn the electricity off at the mains to remove the blue tape first.
Will I expect a live and neutral wire behind the blue tape, and if so do I simply connect the two blues together connect it to the neutral port and then connect the two live together and connect these to the live port or ?
Apart from these two grey cables sticking out of the wall there is a separate on/off light switch a few feet away which will be used to switch the new wall light off and on.
Talk to the electrician. The cables could be looped or they could be switch cable and supply cable. Either way they should not have been left live, so there should be a conection to make somewhere.
One cable will be live and neutral, the other will be live and switchline from the switch. Your light connects to neutral and switchline, it will also need an earth connection if ts a class 1 fitting
You can't say that for sure. There may be more than one fitting, and the supplies need to loop in and out of each. The live loop and switch wiring may well be elsewhere.
Connect the browns together. Your light connects to the two blues.
Is there just one wall light point in the room?
Are the cables connected to a connector block?
If so, where does each wire connect to?
....and
At the light switch for the wall light: how many cables are there?
What colour wires are on which terminals?
