How do I know if my boiler is compatible to a Y plan
15 May 2008
Bedfordshire
Hi I have a concorde WCF 255A and would like to install a fully pumped Y plan system, problem is I can't find the manual so i'm not sure if I can do this - can you help?
Hi I have a concorde WCF 255A and would like to install a fully pumped Y plan system, problem is I can't find the manual so I'm not sure if I can do this - can you help?
The boiler can work with a Y plan; the main problem will be alterations to the pipe work.
Presumably you have a pumped CH with gravity Hot Water.
How many pipes come out of the boiler (apart from gas :wink: ) and what do they connect to?
with a boiler that old I would advise replacement and upgrade all in one go.
