Ideal Concord WCF Boiler Timer control replacement
22 Jan 2011
Bedfordshire
Hi
I have a Concord WCF boiler with a timer control unit built-in.
This timer has recently stopped turning although the switches still work so the heater/water can still be switched on and off manually,
Could someone advise the best replacement control unit for this boiler?
I spoke to someone at Ideal who said any analogue timer unit would do,
Regards
Nick
Siemens RWB 2 is a basic 2 Ch Analogue programmer which is perfectly adequate for your needs :wink:
Many thanks.
Would this be any easy job to fit or require an electrician?
Is it just a case of swapping the units & wiring etc?
Cheers
Nick
