How do I remove and replace my window for a new sofa?
17 Aug 2008
Yorkshire
I have ordered a new sofa and have visions of it not fitting through my door!
How do I remove my UPVC window and replace it afterwards?
It is beaded externally and is a very large panel!
I'm afraid of damaging it.... is it something we can do ourselves or do we need to get someone in? (how much would that cost?)
6 Aug 2008
Cumbria
Its easy take out the edging strip that holding the glass in, use a wallpaper stripper or putty knife to get into the joint between edging strip and the main frame remove glass carefully do not bang it or put it down to hard or it will shatter rest it on a couple of pieces of wood note where the packing pieces are or mark with felt tip on the frame if you cant remember take a picture with phone or camera.
take one strip out and refit for practice before the day that way you will know how on the day itself, good luck much easy with bigger windows if there are two of you to remove and replace the glass
12 Jul 2004
Surrey
assuming your doors are standard 6'6"x2'6" its very unlikly that it wont fit unless the maufacturers state special size requirements!!!!!
commercialy its suacide to make a bit off furniture that you can't sell to the mass market.
i would bet its around 6'3" long and the measurement from where the arms meet the back to the back legs/feet/corner is around 2' ir with feet/legs removed it is
17 Aug 2008
Yorkshire
Thank you SO much Breezer for you words of wisdom.... I will sleep so much better tonight!
I always thought forums were there to offer friendly advise.
21 Jan 2007
Devon
How about measuring the sofa with a tape measure? Or even better, measure it before you buy it. Now thats what I call words of wisdom! :rolleyes:
25 Oct 2006
I had this problem. Sofa arrived, wouldn't go through the door. I rang a window man and they took the pane out for about £20 iirc. It actually much easier than trying to get it through the door!
23 Feb 2007
Belfast
Do they still sell externally beaded PVC windows? I thought they were like leaving a door open for the burglars.
30 Oct 2005
Birmingham
He's right though ;)
More or less the sealed unit will be double sided taped in to the inner part, so even if you get the beading off you'll have to throw a fat man at the glass from the inside to get the unit out. :)
Do some homework with your measurements first. Good luck.
