Hi,I'm not sure what you mean by that.have the side extrusions got packers in them? If they are separate pieces they could come out then the glass slider might come out.
This is what I was worried about,the guys that fitted them left no manual to look at and there is no trade name on them.When opening and closing there feels like there is a slight assist.You may not be able to remove the panels. When you slide them up and down are they counterweighted? If so do NOT remove them from their frame as you will damage the springs within their frames. The only option would be to remove any trims from around the outer frame and unscrew it so you can remove the complete unit.
