Go in through the front. Use an 8mm spanner to remove the single screw holding the grill element in place. Slide out the metal sheet that is above the grill element that will otherwise obstruct you from withdrawing the grill element. Pull the grill element forward as far as it will go without straining the wires connected to it (about 3 or 4 inches). This will pull a couple of inches of the wires through from the back. I recommend you secure these with clips to stop them retracting back through the hole into the back of the oven when you disconnect them. Then disconnect the wires from the grill element by sliding them off. Remove the existing grill element. Install the new element.
