I'm sure this is basic stuff, but would really appreciate any help.
I have a light fitting with halogen bulb. The bulb blew, so I bought another one exactly the same. Put bulb in, turned light on, nothing. Odd. Tested the bulb with my circuit tester. The beep beeped, meaning it was intact. Took light fitting off wall and tested it with new bulb in, by putting my prong things on the junction connectors, that I had just detached from the mains power. The beep beeped, so it's not the light fitting that is at fault. There is no transformer to worry about, so that just leaves me wondering if there is any power coming out of the mains wires. There was two days ago, when the light worked. Also, at no point has the circuit breaker tripped. How do I test whether there is a sudden wiring problem? Obviously if there is, then I will get an electrician in, but if there's something I can do myself, I'd rather.
I have heard that you can't actually test for a complete circuit in a halogen bulb with a little battery powered circuit tester. Is this correct. Should I go and buy another bulb, just to check? The one I've got looks fine...
