I Ian_O Joined 28 Oct 2006 Messages 2 Reaction score 0 Location Yorkshire Country 28 Oct 2006 #1 Is there a drain plug? Do you need to take off the bottom hose? If so, how do you access it?
B Belle427 Joined 16 Jan 2006 Messages 3,229 Reaction score 362 Location Newport, S Wales. Country 29 Oct 2006 #2 usually from underneath by drain plug or if not present release bottom hose
D davieboy Joined 20 Dec 2004 Messages 237 Reaction score 12 Location Fife Country 30 Oct 2006 #3 are you wanting to drain it to change it? if it's the pink coloured coolant (should be) then this has a 10 year life, not like normal anti-freeze.
I Ian_O Joined 28 Oct 2006 Messages 2 Reaction score 0 Location Yorkshire Country 30 Oct 2006 #4 I need to change it. The current coolant will only be adequate down to zero degrees C. I am told you should not mix types and can't tell the colour of the current stuff so figure it's best to change it. I know I can remove the bottom hose, but access to it is a problem so wanted to know where the drain plug was if there is one ( Cos I can't see it).
H Heyyouitsme Joined 24 Oct 2006 Messages 60 Reaction score 0 Location Liverpool Country 31 Oct 2006 #5 if there is a drain tap it would be on the bottom of the rad, so either way your doing to have access probs, it would be quicker to remove bottom hose as the drain tap will take for ever to empty the cooling system
