Groove toward wall with suitable expansion 2-3mm per metre = 10mm expansion gap.
First piece must need secret nail fixing on both edges, so how (since there's no luxury of 90 deg fix due to edge being 10mm off wall) do you fix the first run, and then the last run.
Flooring system is Elka and I intend to use:-
Since the expansion gap will be 25mm strip, do I just screw down vertically making sure the screw head is covered by the expansion strip cover ?
While I'm at it we intend to have a new fire installed, am I okay to tuck the flooring under the heath ?
The heath can be raised and centrally supported so that the hearths vertical edge is floating, thus isn't weight bearing on the floor.
