Hi all, I've had quite a few solar panels quotes from different solar companies and I realise I have asked questions that they might not have been able to answer correctly as they were the salesmen and not the electricians doing the work.
I think one of them said they will connect the inverter to one spare MCB of the consumer unit, is this correct?
I have a consumer unit with a single RCD for both rings and two non RCD lighting circuits; if they connect a new MCB to the RCD side of the consumer unit, doesn't that mean that in case of a fault on one ring, the rcd might not disconnect because the current is flowing from the inverter to the ring directly without passing through the RCD (as there is no power drawn from the grid)?
