How does one unStiffen single lever Ceramic taps?
7 Jan 2005
What is the secret of unstiffenening single lever Ceramic taps? Some times more or less virgin tapes become very stiff through lack of use what is the secret method of freeing them up?
Er.. use them (but don't tell anyone, it's a secret) :)
Hmmm well i've been using mine for a couple of years, and its not getting any looser. Mine is a cheap one from MFI...
I put in my fitted kitchen several years ago (from MFI) which used a mixer tap with those quarter turn from off to full
First time I turned it on, got an awful crunching sound and found that the ceramic bit had fallen apart - albeit from my forcing it a bit to free it
Fair play to MFI they changed it on the spot (when I demanded to see the manager and refused to leave the store at closing time)
This one has worked without problem for many happy years
:D :D
sounds like it might need taking appart and silicone grease applying to the discs. However I have only experience in servicing 1/4 turn, I've never needed to dismantle a single lever type.
If u live in a hard water area the limescale gets into the moving parts and stiffens them up.
Try brushing on vinegar with an old toothbrush working it into all the nooks and crannnies (on the tap that is), it does work.
Let us know waht happens
The ceramic disc type taps had the original selling point of not being affected by hard ward, as the ribbing action on the disc stoped lime scale forming, they also claimed that they didn't wear. They do & are not cheap to replace.
