How good is 'Satinwood' paint
13 Feb 2006
Tyne and Wear
I've always been an undercoat 'n gloss type of guy, but I suppose times move on.
I have some new glazed doors to paint, as well as skirting boards, architraves etc, so was thinking about water-based undercoat and gloss (white)
I was in Wlko and see this plan of action, using their own brand paint may take up to 3 coats, so that idea 'is out the window'.
They had Dulux Satinwood 2.5 litre tins, for £20, down from £26 .. both their 'conventional' Once paint and Quick dry.
Which one of these is best ?
thank you
Or ... is the undercoat / gloss route a better bet ??
I did my stairs (steps, stringer, etc.) in it, along with all the architrave and skirting in my front room, hall and kitchen and I really liked working with it. It was on offer at the time and along with the name 'Dulux' that's probably why I went for it. It leaves a subtle, very low sheen. Once I'd de-nibbed and put another coat on the finish was lovely.
The only thing I have noticed is that areas which don't get much sun have started to go slightly yellow. I painted it between 2017 and 2018 so it's not particularly old.
I've since started using the 'No Nonsense' stuff from Screwfix and really like that, too.
I always used to use gloss but have been using satinwood for the last few years. I like it. Easy to put on, doesn't smell and dries pretty quickly.
Did you use the oil-based 'Once' paint, or the quick drying water-based paint ?
I used the oil-based paint, with two coats. My only criticism is that it's gloopy and a bit less easy to work with. I prefer the water-based paints even if a bit thinner -- they flow more easily.
Satinwood rocks! One coat is usually enough but two can be used in hard wearing areas for extra protection. I love the stuff. It doesn't stink up the place, easy to wipe clean, easy to clean the brush. Bless the cotton socks of the clever elves who came up with this stuff, say i.
Oil is better but it yellows. So, it is worst. For sun flooded exterior, oil is best. I have long life oil that kept going for 10+ years with no sign of failing.
