Cant argue with that. (Im sure some will try though) thanks dan
is that bol locks then?the idea of putting rads under the window is an old one. With draughty old single glazed windows there, the heat loss is highest, so the maximum heat goes straight outside to warm the sky. .
and that?If energy was free you might not mind. .
and that?It also prevents you having long curtains. .
Modern glazing and curtains mean that the cold area next to the window is not such a problem for comfort now,
but it is still the worst place for energy loss. .
or is it just that bit you object to? after you've tipped a vast amount of energy out to warm the birds?A rad on an internal wall is better for comfort throughout the room.
I knew this was going to happen
Heat loss is not the issue.
No, heat loss is directly proportional to the temperature difference between the hot and the cold object.Heatloss from he room is going to be the same regardless.
