Bloody PVA again;
DO NOT USE STANDARD PVA ON A TILING BASE or your tiles may well fall off.
DO NOT USE AN SBR PRIMER UNLESS YOU’RE ADHESIVE MANUFACTUREER RECOMENDS IT.
This time of year a plaster skim should be left 7-10 days before tiling, although it may have gone pink & looks dry, there will still be a residual moisture in the plaster. Tile over it & you will trap the moisture, it will take longer to set & could affect tile adhesion.
