How long to change a boiler
Problem for me is no local Intergas installer .....Intergas website only brings up 1 guy, and he advised I’m outside of his normal working area.
Seems to be not very well known or used boiler in this area.
However I’ll do some digging on options, then put a new post.
Care to help with estimate on time ?
I think my loft fitted, like for like heat only boiler swap using my existing flue hole took about 6 hours but I had cleaned and flushed the system beforehand and had routed a condensate drain which they checked before connecting up to it.
You don't have to use an Intergas approved installer. You'll get the same warranty whoever fits it, and they're really simple boilers to fit.
Is you cylinder prelagged,do you have trv's, how's the condesate going to be plumbed, does the flue position confirm to current regulations.
And you need controls in the equation. If you have an Inter gas fitted it can always be plumbed in as a combi later on ! It would just need the cold supply to it and the hot outlet plumbing in. It's a no brainer.
